"I use my 8HP Tohatsu 2-stroke
"I use my 8HP Tohatsu 2-stroke on my dink, which means it on/off my dink multiple times/day. The o-ring in thefuel line connector to the engine got pinched and it started leaking at the end of last season. I contacted Tohatsu who could provide no information about the correct o-ring to use. I measured the o-rings myself and ordered replacements from McMaster-Carr online (mcmaster.com) and they fit perfectly. I just wanted to share this with the group since I'm sure MANY engines share the same fuel line hose and connectors. If you need a set here's the information:
9262K401 Metric Buna-N O-Ring 1.8 mm Width, 12.5 mm ID, Packs of 100 (Same as 9262K41) $8.25
9262K128 Metric Buna-N O-Ring 1.5 mm Width, 12 mm ID, Packs of 100 (Same as 9262K41) $6.15
I now have enough to last me 100 years! ;-) Hope this helps someone out there..."
