I have a 50ESL71S I had a neut
I have a 50ESL71S I had a neutral problem and i fixed that now I have a different problem. I have no power to anything. Im geting power to the starter solenoid but no power to the key switch. I put a jumper wire from the battery to the ignition switch and got power to turn the starter. It will start but nothing else seems to be working. The carburetor solenoid doesnt seem work when i do get it started i have to stand back by the motor and manually control the throttle shaft or it will run wide open any insight will help THANKS.
