Click for Honda Manuals, Parts and Model Guides!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2009
    Location
    tampa, Florida, USA
    Posts
    3
    Default "Hi guys- I stumbled upon this
    "Hi guys- I stumbled upon this site and it seems like a wealth of knowledge, so I figured I would give it a shot. m I am having a problem with my 2001 Honda BF50 engine.
    It idles somewhat rough, but not too bad for an older engine with alot of hours on it.
    The real problem that I am having is that when I throttle up too fast it stalls out, or when I try to power the boat onto the trailer it stalls out too. It seems to have a dead spot at about 2500-300 RPM, and I have to verrryyyyy sloowwwly throttle up through that RPM range or else the engine sputters out and stalls.
    The carbs were just recently cleaned out, but I am not sure if they need to be adjusted or something? Any advice would really be great because I am not satisfied witht he engines performance at all. I just got the boat about a month ago.
    Also, it does not have this problem when the boat is not in gear. I have revved it up while flushing the engine and it does not stall out like this. Any ideas??"
  2. #2
    Join Date
    Jan 2009
    Location
    Malta
    Posts
    6
    Default "If your engine date of manufa
    "If your engine date of manufacture is pre June 2000 check out the Honda Service bulletin attached. I replaced my carb assembly on my 1999 BF50 as per bulletin and haven't had any problems since.
  3. #3
    Join Date
    Jan 2009
    Location
    tampa, Florida, USA
    Posts
    3
    Default "It is a 2001 model year, but
    "It is a 2001 model year, but how do I find out when it was actually manufactured?"
  4. #4
    Join Date
    Jan 2009
    Location
    Malta
    Posts
    6
    Default "im not sure but i beleive the
    "im not sure but i beleive there is a plaque with model id and serial at the transom bracket and and date of manufacture below pivot tube, i can't verify cause i can't visit my boat this weekend.
    You might also want to check your carb model id by looking at the top carb while looking down at the flywheel. The carbs that caused problems were BG31A(A)"
  5. #5
    Join Date
    Jan 2009
    Location
    tampa, Florida, USA
    Posts
    3
    Default doea anyone know how to adjust
    doea anyone know how to adjust the carbs to make the engine run richer? a few people have told me that might be the problem
  6. #6
    Join Date
    Jul 2008
    Location
    Tauranga New Zealand
    Posts
    122
    Default "With regard to your dead spot
    "With regard to your dead spot at 2500 rpm when throttling up. Providing the carbs ARE cleaned out properly & spark plugs have been renewed, then I would say it's caused by either stale/low octane fuel, or faulty thermostat(causing engine to run too cold)."
  7. #7
    Default "have the same problem and add
    "have the same problem and additionally some gas in the oil.
    got the tip the check the fuel pump, but that actually is fine.
    so i am going to replace the carbs"
  8. #8
    Join Date
    Mar 2008
    Location
    , Florida,
    Posts
    279
    Default "Gas in the oil can be a sympt
    "Gas in the oil can be a symptom of thermostat problem as well as Fuel Pump.
    Running without a thermostat can cause uneven circulation and 'spot' overheat as well as gas in oil.
    Take it out and clean it; to test, put it in a pan of water on your stove with a candy thermometer and see that it opens at the spec (from your Shop Manual).
    _________________________________________________
    For my BF75/BF100 SM it lists "full closed at 50-70c (122-158f)" depending on s/n and "full open at 60-80c (140-176f)" depending on s/n.
    Shop Manual also lists a Valve Lift of 2-3 mm (0.08-0.12 in) or 3-4 mm (0.12-0.16 in) again depending on engine s/n."
Similar Threads
  1. Honda BF50 Throttle up Issue
    By rcs71* in forum Honda Outboard Forum
    Last Post: 11-26-2010, 01:17 PM
  2. Smoke coming from lower unit 2001 BF50
    By mikeczipri in forum Honda Outboard Forum
    Last Post: 11-08-2010, 04:20 PM
  3. 2001 350 MPI Stalling and Slight misfire
    By scooter111 in forum Mercruiser Sterndrive Forum
    Last Post: 11-29-2009, 04:17 AM
  4. 2001 BF50
    By David Baines in forum Honda Outboard Archive
    Last Post: 07-21-2007, 11:41 PM
  5. Stalling at full throttle
    By bigblock396ss in forum Johnson Evinrude Outboard Archive
    Last Post: 04-10-2007, 02:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
