2003 50hp 2 stroke
zackfactor
"i am out of ideas on this one
"i am out of ideas on this one. motor is a 2003 50hp 2 stoke. plugs are soaked with gasoline. i unhooked the primer and still have the same result. cleaned carbs, same result. i dont know where else to look, any ideas?"
"I have a 2002 50 TLRA 50 hors
"I have a 2002 50 TLRA 50 horse 2-stroke oil injected engine.The trim and tilt gauge does not read correctly.It shows full up without power,a little off of down when you turn on the switch,but doesn't move when you activate the trim or tilt switches.The trim and tilt motor works fine. Does anyone know where the sensor and ground wires attach to the engine?}"
I have the opposite reading pr
I have the opposite reading problem on my 200. (only shows 2 bars max) My Yami mechanic buddy told me not to worry about it.... but that if it reads fully up it can trigger the engine to go into safe mode...as it thinks the engine is being run out of water.
