Results 1 to 27 of 27
  1. #1
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default Could any one tell me if a 199
    Could any one tell me if a 1998 Evinrude model no.E115TSIEMis suppose to be able to charge the starting battery or not.I have benn told that it does and another said it did not.It has never charged since it was brand new.
  2. #2
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,200
    Default The model number does not make
    The model number does not make sense to me. A '98 model should include the year letters EC .
    Should it be E115TSLECM ?
    As far as I can see 1998 115 models will either be fitted with a (water cooled)regulator/rectifier or one of the round non regulating rectifiers (three wire). (The latter in the case of TSL models) Depending upon the exact model.
    Which ever it should provide a battery charging capability.
    The rectifier may have been blown as a result of connecting the battery the wrong way round. .... Instant death.
    The round 3 wire (and 4 wire) rectifiers can easily be checked using a multimeter with a diode check range.
  3. #3
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default "I MADE A MISTAKE ON THE MODEL
    "I MADE A MISTAKE ON THE MODEL NUMBER, BUT IT IS A 115TSLEM.ON THE TAG IT DOES SAY A 1997 MODEL INSTEAD OF 1998.COULD YOU TELL ME WHERE THE RECT. ARE LOCATED. AND HOW TO TEST. THANKS"
  4. #4
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "the regulater/rect is one ,on
    "the regulater/rect is one ,on that eng.unless maybe a commercial....top of block,behind flywheel....has yellow wires going to it,a gray,and a red."
  5. #5
    Join Date
    May 2008
    Location
    Posts
    1,200
    Default "The date letters for 1997 are
    "The date letters for 1997 are EU so the model number should be E115TSLEU followed by a suffix letter.
    Either look at THIS DIAGRAM or locate your engine in the PARTS CATALOG and look at the diagram for the ignition system.
    The water cooled rectifier regulator (which it seems is fitted to the TSX (25") models) is shown as part #82 in the diagram in my link and the non regulated rectifier (fitted to TSL (20") models) is shown as part #79.
    I can't help with testing the regulated type but the non regulated one can be tested as follows.
    Disconnect the leads from the nearby terminal strip (remove the rectifier completely if you prefer)
    Connect one lead of a multimeter set to the diode test range to the red lead and the other to one of the yellow leads. Note the reading if any.
    Reverse the meter leads. If you had a reading above you should now not have a reading or vice versa.
    Now repeat the above between the red and the other yellow.
    Then repeat the whole procedure between the case and the two yellows.
    Each time you should get a reading with the meter connected one way but not if connected the other.
    Each test is on one of the four diodes that make up the rectifier.
    If you have any blown diodes in there you'll get no reading in either direction on them. If it has been blown by connecting the battery the wrong way you'll find two blown diodes at least.
    BTW some motors have a 4 wire rectifier, with 3 yellow leads. Extend the above to the third yellow in that case as they have 6 diodes)
    Sometimes it is possible to use one of the ohms ranges of a meter that does not have a diode test range, but not all meters work on all the ohms ranges and some work on none of them. One of the higher resistance ranges is most likely to work if any do I think.
    IF JWB is right, and he probably is, then it has the watercooled rectifier/regulator regardless of the shaft length."
  6. #6
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default "IF IT IS CHARGING, CAN YOU TA
    "IF IT IS CHARGING, CAN YOU TAKE A REGULAR DC VOLT METER, OR AMP METER AND HOOK TO THE GROUND AND HOT OF THE BATTERY CABLES AND TELL. IF SO HOW MANY VOLTS OR AMPS SHOULD IT BE PUTTING OUT ON THE TESTER. THANKS, RANDY"
  7. #7
    Join Date
    May 2008
    Location
    Posts
    1,200
    Default I thought you said it wasn'
    I thought you said it wasn't charging!
    But you can check with a voltmeter. Read the battery volts before you start. If the battery is good and charged it should be abt 12.7 volts. Start up and watch the volts. It'll fall during starting but then should rise to a figure well above the 12.7 but you will have to rev the engine a bit. To be charging effectively you need 14volts +/- 0.2 volts. An unregulated rectifier will give a much higher figure as the battery recharges and you increase the revs.
    You could check the current if you know what you are up to. Remember an ammeter goes in series and must not be subjected to the starter motor current.
    Good luck its gone 2 o'clock in the morning here. I'm off to bed!
  8. #8
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default "THANKS VIC, . I RECHECKED THE
    "THANKS VIC, . I RECHECKED THE MODEL NUMBER AND IT IS CORRECT. IT IS A TSLEM, MANUFACTURED DATE 09/1997.I CAN NOT TELL IF IT IS CHARGING OR NOT WITH A BATTERY/ VOLT TESTER. I JUST BOUGHT THE BOAT FROM THE ORINGAL OWNER AND HE SAID THAT IT HAD NOT CHARGED SINCE HE BOUGHT THE BOAT BRAND NEW. HE HAS ALWAYS USE A 2 BANK CHARGER ON THE STARTING BATTERY AND THE TROLLING BATTERY.HE SAID THAT WAS THE ONLY WAY HE COULD KEEP THE BATTERY UP.SO HE TOLD ME THAT IT NEVER HAD CHARGED.SO FROM WHAT I AM FINDING OUT FROM YOU GUYS , THER IS SOMETHING WRONG WITH IT IF IT IS NOT CHARGING.I DON'T KNOW MUCH ABOUT OUTBOARD MOTORS.WHEN I PUT A VOLT METER ON THE BATTERY IT SHOWS AROUND 12 VOLTS WITH THE ENGINE OFF AND WITH IT RUNNING ALSO.IT DOE NOT INCREASE LIKE THE VOLT METER DOES ON A CAR.THAT IS WHY I AM TRYING TO FIND THE BEST WAY TO TEST FOR CHARGING. THANKS FOR ALL THE INFO. IF ANY THING ELSE YOU KNOW TO HELP PLEASE LET ME KNOW. THANKS, RANDY"
  9. #9
    Join Date
    Jul 2008
    Location
    sallisaw, oklahoma, usa
    Posts
    930
    Default do you have a tachometer? i
    if you do and it is working you should be charging.
  10. #10
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default "YES IT HAS A TACH AND YES IT
    "YES IT HAS A TACH AND YES IT DOES WORK. SO THAT IS A SURE WAY THAT YOU CAN TELL IT IS CHARGING.THANKS, RANDY"
  11. #11
    Join Date
    Jul 2008
    Location
    Posts
    930
    Default "if you the water cooled type
    "if you the water cooled type behind the flywheel , instead of the round rectifier with three wires, it should have a voltage regulator which will not show drastic differences like the unregulated rectifiers......... a car alternator puts out a lot amperage than a boat..........and if your car voltage gauge works like a tach when you rev it up you are more than likely on the verge of buying a new voltage regulaotr, complete alternator, or a new battery which ever is the culprit.
    as stated above DO NOT hook up your batt cables backwards------IT WILL kill your regulator instantly......already been there."
  12. #12
    Join Date
    May 2008
    Location
    Posts
    1,200
    Default "[i]do you have a tachomet
    "do you have a tachometer?
    A tachometer needs a power supply and an input signal. Yes ? It gets the input signal from the ac output from the stator? In the absence of a battery (on a hand started engine for example) the power supply comes from the rectifier.
    Am I correct?
    Now if the rectifier is blown but there is a battery connected the tacho will get its power supply directly from the battery and therefore still work. Or have I missed something.
    The voltage tests Randy has done do indicate that the rectifier is blown BUT there could be a connection off somewhere. There is a fuse in there too. I dont know what circuit that's in but it would be sensible to check it.
    Even a regulated rectifier will show a rise in volts if it is charging. Just like a car voltmeter ... that's regulated!
    Check the volts at the red wire from the rectifier. If there's a bad connection or a fuse blown then there will be no volts when the engine is not running but if the rectifier is OK there will be when it is running.
  13. #13
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default "THANKS FOR THE INFORMATION.WH
    "THANKS FOR THE INFORMATION.WHERE IS A GOOD PLACE ON THE INTERNET TO GET A SERVICE MANUEL FOR THIS ENGINE THAT HAS A DETAIL, AND PICTURES OF REPLACEING THE RECT, AND SHOWING EXACTLY WHERE IT IS LOCATED ON THE ENGINE. THANKS FOR EVERYTHING, RANDY. PS IS THIS A JOB FOR A BOAT SHOP OF IS IT PRETTY EASY TO CHANGE"
  14. #14
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "u can chg it----look at top,l
    "u can chg it----look at top,left under manuals...get a 'factory' service manual.."
  15. #15
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "if ur tach,..is wking,...u do
    "if ur tach,..is wking,...u dont need a reg/rect.
    unless---it is reading wrong..
    unusually high--low/erratic."
  16. #16
    Join Date
    Jan 2009
    Location
    west l , ky, usa
    Posts
    7
    Default "THERE IS NO SERVICE MANUEL L
    "THERE IS NO SERVICE MANUEL LISTED FOR THIS MODEL NUMBER. IS THERE A CROSS OVER NUMBER. THANKS, RANDY"
  17. #17
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "ur model number,does not appe
    "ur model number,does not appear correct......
    however,..this is the one,for 97 115--
    0507267--what i am recommending,is a full factory service manual---this,appears to maybe,be a copy,i dont know...ask andrew menkart on here...."
  18. #18
    Join Date
    Nov 2005
    Location
    Chesapeake, Va, US
    Posts
    1,111
    Default "You tach works off an AC puls
    "You tach works off an AC pulse from the stator. You can take the rectifier/regulator out and throw it away and as long as the tach is connected to one of the yellow wires coming from the stator, it will work (if the stator is good). The connection for the tach is made at the rectifier/regulator simply because it is a convenient place to make it. The 2 yellow wires coming from the stator feed a full wave bridge rectifier consisting of 4 (sometimes 6) diodes. It depends on which diode gets damaged whether it will affect the tach or not. Bottom line is the charging system can be damaged but the tach still work."
    Bill H PTC USN Ret
    A manual is a cheap investment.
  19. #19
    Join Date
    Aug 2008
    Location
    Posts
    433
    Default "Check AC voltage from the sta
    "Check AC voltage from the stator... if you have voltage there, then check and recheck the rectifier, red wire coming out from the rectifier (to battery) should have at least 13 V right after you start the motor due to the voltage lost due to cranking the motor, but voltage should be never higher than 14.6 V… a bad battery could cause blown diodes in the rectifier…"
  20. #20
    Join Date
    Dec 2008
    Location
    , Ky,
    Posts
    5
    Default "Why can't you check with
    "Why can't you check with a dc voltmeter? Check the voltage first at the battery, then start and let run and check again. It should read around 12.5 VDC, and then go up to around 14VDC +/- while running. If it's not charging the voltage will drop after it's running. Any volt/ohm meter will read 12vdc."
  21. #21
    Join Date
    Aug 2008
    Location
    Posts
    433
    Default Stators put out AC voltage tha
    Stators put out AC voltage that then is "corrected" by the rectifier and turned in to DC... so if there is no AC to beging with you will not have any DC to go and charge you battery...
  22. #22
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default exactly
    exactly
  23. #23
    Join Date
    Dec 2008
    Location
    , Ky,
    Posts
    5
    Default "I was refuring to Randy's
    "I was refuring to Randy's eairlyer comment. He said, "I can not tell if it is charging or not with a Battery/volt tester". Sorry for the confussion.
    Someone else suggested it, so i thought i would ask about is comment.I use that test as a basic indicator of the charging system. Keep up the great work guys."
  24. #24
    Default "With the tach you cant always
    "With the tach you cant always say it is charging or not, I had 93' 70 hp that charged at an idel , but when I went above 1800 rpm, the tach droped like a rock and so did the charging. even though it passes all tests it still could be a bad regulator. Try to get a used one and try it out then."
  25. #25
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    Default lets try to trap this problem
    lets try to trap this problem to find out exactly whats going on..take a reading from the negative to the positive post on the battery...on a fully charged battery this should be 12.7 volts or close to it...write this reading down...start engine and run at approx 2000 rpm....let it run for 5 minutes before taking any additional reading...let motor continue to run...leave your meter leads across the battery...take a reading and write this down...leave the negative meter lead on the batery...move the positive lead to the red wire output of the regulator..take a reading....write it down...move the negative lead of the meter to a good ground on the motor...write this reading down....get back to us with the readings...respectfully...Carl
  26. #26
    Join Date
    Feb 2009
    Location
    , Delaware,
    Posts
    1
    Default "i have a 96 johnson 90hp ocea
    "i have a 96 johnson 90hp ocean runner. the tach works but is not charging. new battery, terminals and connections clean and tight. any ideas? thanks"
  27. #27
    Join Date
    Sep 2006
    Location
    Posts
    2,501
    Default Carl....you should start anoth
    Carl....you should start another string on your problem...however read my last post..it applies..
Similar Threads
  1. Charging Evinrude 50hp
    By tedheath in forum Johnson Evinrude Outboard Archive
    Last Post: 07-20-2008, 05:39 AM
  2. 28 HP evinrude not charging
    By qlty in forum Johnson Evinrude Outboard Archive
    Last Post: 06-22-2008, 10:32 AM
  3. 89 evinrude 120 charging system
    By randy in forum Johnson Evinrude Outboard Archive
    Last Post: 05-11-2004, 07:31 PM
  4. 65b evinrude charging system
    By mrcipp in forum Johnson Evinrude Outboard Archive
    Last Post: 06-24-2003, 07:26 AM
  5. Evinrude charging system
    By Howie Hogle in forum Outboard motors archive 2000-2004
    Last Post: 04-13-2001, 08:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
