Help wanted please had a bad day
"PS It mightn't be a bad i
"PS It mightn't be a bad idea to install a rev counter,it'll show you if you are getting the recommended revs at wot."
"Any tacho will do and the har
"Any tacho will do and the harnesses are available to plug into your control box or wire direct.If you do go for a tacho be careful when connecting the harness to the tacho, fried tachos are an expensive lesson.I have that particular t-shirt.
"I would double check the dire
"I would double check the direction of the impeller. I have twins and I inadvertently installed one of my impellers backwards. I was very careful to install it right and still managed to put it in wrong. The engine temp slowly crepped up until the warning buzzard sounded. I reversed the impeller and the engine now runs very cool. When the impeller was backwards, I had water coming out of the pee hole but with less pressure.
It is very easy to accidentally install the impeller backwards."
make sure its a brand new inpe
make sure its a brand new inpeller and facing the correct way and the key seal is located firmly i had same problem if your impellar looks like a starfish its stuffed
make sure everything is sealed tight around the gasket and the waterpump
