"My 1991 Wellcraft 3300 Costal
"My 1991 Wellcraft 3300 Costal has a pair of 454’s in it. It runs OK but I want to check the timing and can’t make sense of the factory book. Without unplugging any connectors or jumping wires this is what I see: ( I may be wrong on the direction of rotation and I can't seem to paste in the drawing of the timing mark and teeth I made)
PORT ENGINE ~ timing mark about 1.5 inches before the start of the teeth or ~ 25 deg BTDC
Starboard Engine ~ timing mark about .75 inches before the start of the teeth or ~ 15 deg BTDC
The Crusader service manual tells me to change the timing plug to “TIME” position before I adjust the timing mark to 10 deg BTDC. This is the part I really don’t understand. It looks to me like without the timing plugs changed I’m at ~ 20 to 25 deg BTDC.
The engine starts and runs fine but not knowing that the timing is set correct, so I can adjust the mixture and idle bothers me. The timing mark does advance toward the teeth when I rev the engine."
