Click for Volvo Penta manuals!
Results 1 to 2 of 2
  1. #1
    Join Date
    Jan 2009
    Location
    MÃĄlaga Spain
    Posts
    1
    Default "Hi Frieds, i have a problem w
    "Hi Frieds, i have a problem with my Volvo 2003, if I run the engine in navigation, I can get hot water for the shower in 15 minutes, but if I run the engine while anchoring, even if I revolution it untill 1.500 rpm, after one hour, i still canīt get hot water. Anyone have this problem?."
  2. #2
    Join Date
    Jul 2007
    Location
    North Charleston, South Carolina, USA
    Posts
    52
    Default "The key here is to look at th
    "The key here is to look at the engine temperature gauge. If the engine is not getting hot, the water in the water heater will not get hot.
    My TAMD41P gets to 180 degrees or more under load and the hot water can be dangerously hot. At idle, it only reaches 120 degrees or so.
    That's with new thermostats."
Similar Threads
  1. Volvo Penta 2003 fresh water cooling pump
    By perry_basden in forum Volvo Penta Diesel
    Last Post: 01-29-2014, 09:52 PM
  2. 2003 50hp Johnson 4-stroke Long Beep Alarm
    By lipinski in forum Johnson Evinrude Outboard Forum
    Last Post: 02-18-2012, 04:59 PM
  3. Honda 225 hp BF year 2003. Beeper sounds long intermediate beeps
    By nikosxatz in forum Honda Outboard Forum
    Last Post: 06-21-2010, 01:26 PM
  4. 2003 115 four stroke how long should it be warmed up
    By leros in forum Mercury Mariner Outboard Archive
    Last Post: 09-28-2009, 09:40 AM
  5. Conversion of 2003 90 HP Honda Long Shaft To Short Shaft
    By richardlandrews in forum Honda Outboard Archive
    Last Post: 07-06-2007, 05:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
