Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 5 of 5
  1. #1
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "The throttle on our 18hp Toha
    "The throttle on our 18hp Tohatsu has bound up ?.After pulling everything apart it apperas the piece that is sticking is the telfon cam which the throttle rod passes into the back of ,this is the piece which stays attached to the motor when the tiller is removed any ideas on how to remove this bit ?"
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default As this would be covered under
    As this would be covered under warranty I would urge you to stop working on it yourself. Just run it by your closest authorized dealer.
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "We are 3 hrs away on holidays
    "We are 3 hrs away on holidays ,it seems the cam ? is seized cant see how to take it out ,motor is brand new ."
  4. #4
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default What's the zip code where
    What's the zip code where the engine is now?
    Elvin
  5. #5
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "Thanks for your reply. I s
    I slid the cam out of the housing and it was a real tight fit ,IE binding up ,i gave it a light sand re greased and re assembled,all is good.
    My concern was there was a grub screw holding the arm or part on which i couldnt see."
Similar Threads
  1. Tohatsu 18hp leaking fuel
    By Marinodman in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-13-2010, 10:59 AM
  2. 18hp 4 stroke Tohatsu Carb
    By wam in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-02-2009, 07:33 AM
  3. Tohatsu 18hp Impeller
    By olmo40 in forum Nissan Tohatsu Outboard Archive
    Last Post: 12-30-2008, 04:54 PM
  4. Tohatsu 18hp 4 stroke
    By tohatsufreak in forum Nissan Tohatsu Outboard Archive
    Last Post: 09-13-2008, 08:28 AM
  5. 18hp Tohatsu
    By whfmznb in forum Johnson Evinrude Outboard Archive
    Last Post: 04-04-2003, 09:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
