Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 2 of 2
  1. #1
    buffaloman321's Avatar
    buffaloman321 Guest
    Default "I have a two year old 9.8 Toh
    "I have a two year old 9.8 Tohatsu four stroke. It has performed flawlessly up to the point that a leaking gas tank received a lot of water through a defective filler cap. Tank was stored outside in two severe rainstorms. Local Tohatsu dealer cleaned out the tank. Second storm gave us same symptoms and I bought a new tank and moved the fittings. It ran intermitantly and finally would not run at all. I can hear air leaking in the hose system, I believe in the fuel line in the motor under the cowl it isa small noice intermittant when priming the fuel ling.Pumping the fuel line does not seem solid. I have dissassembled the the carburetor and an preparing to soak it. The gasket seperating the float compartment appears to be stuck in a small amount of rust. My question is do I have to remove this gasket and one other nylon washer on the choke control befor soaking this carb?"
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default The gasket...Yes. The washer..
    The gasket...Yes. The washer...No.
    Elvin
    Solution One Maritime
Similar Threads
  1. Tohatsu Oil leak out of prop
    By cfoster in forum Nissan Tohatsu Outboard Forum
    Last Post: 03-02-2010, 04:53 PM
  2. Carburetor
    By rick_jacobs in forum Mercruiser Sterndrive Archive
    Last Post: 06-29-2008, 08:49 PM
  3. Same carburetor
    By jjdluz in forum Yamaha Outboard Archive
    Last Post: 01-25-2008, 01:47 AM
  4. 40 HP Tohatsu Carburetor Adjustment
    By Jay Alexander in forum Archive 2003-2007
    Last Post: 09-28-2007, 04:26 PM
  5. b98 Honda 90 carburetor leak
    By markwsc in forum Suzuki Outboard Archive
    Last Post: 12-28-2005, 04:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
