Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "Our 99 model tohatsu 18hp jus
    "Our 99 model tohatsu 18hp just chewed up an impeller ,does anyone know if this part is interchangeable with a merc Impeller from say a 15hp"
  2. #2
    Join Date
    Sep 2008
    Location
    wouldnt you like to kno, not sure, the usa
    Posts
    87
    Default no not the two stroke 15hp me
    no not the two stroke 15hp mercurys completely different motor as far as the newer four stroke 15hp mercury last one i saw had a merc gear case on it like the first year of the nissan four stroke 9.9-18 so no but the new new ones might be the same they say there re badged tohatsus but i have found small differences ( for example the accelerator pump boots are slightly different) but i dont see 15hp mercs in my area very much so im not totally sure about the 4 strokes
  3. #3
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "Thanks , Found a new Tohat
    "Thanks ,
    Found a new Tohatsu one fitted it ,chewed out in 2 hrs of use ??? aaaagh .Small motors are not my forte,am i missing a Tohatsu trait 99 ,18hp,fully rebuilt ."
  4. #4
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default 2 stroke
    2 stroke
  5. #5
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default "Your problem is that you chan
    "Your problem is that you changed out the impeller and did not change out what wore out the impeller in the first place. Never replace the impeller without replacing the liner and wear plate in the water pump. Get a water pump kit which is available from any Nissan or Tohatsu dealer. Also, there are two Mercury four-stroke 15's presently being offered. One is made by Tohatsu and uses the same water pump as you. The other Mercury 15 is the retarded love child of the Yamaha/Mercury hybrid and is not compatible."
    Elvin
    Solution One Maritime
  6. #6
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "Thanks Guru , I didnt repl
    "Thanks Guru ,
    I didnt replace the liner and wear plate as they only did 5 minutes work before eating the first one.I will get another kit and try again.
    All this mercury / yamaha /tohatsu mix gives me brain damage .
    Regards"
Similar Threads
  1. Tohatsu 18hp leaking fuel
    By Marinodman in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-13-2010, 10:59 AM
  2. 18hp 4 stroke Tohatsu Carb
    By wam in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-02-2009, 07:33 AM
  3. 08 Tohatsu 18hp
    By olmo40 in forum Nissan Tohatsu Outboard Archive
    Last Post: 01-06-2009, 11:55 PM
  4. Tohatsu 18hp 4 stroke
    By tohatsufreak in forum Nissan Tohatsu Outboard Archive
    Last Post: 09-13-2008, 08:28 AM
  5. 18hp Tohatsu
    By whfmznb in forum Johnson Evinrude Outboard Archive
    Last Post: 04-04-2003, 09:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
