"I cant make a ski start anymo
"I cant make a ski start anymore. The motor bogs down. If I ease the throttle gradually it is possible to reach approx 3000rpm, suddenly, it will accelerate very quickly as before. In this weak interval using the switch key (priming) will improve signifficantly. Using the primer bulb though will do nothing.
This has happened after a carb clean due to bad idling. Now the idling is fine, but I got this new problem. WOT is also very good.
The carb linkage and cam is adjusted. Compression is 120 psi on all 3 cyls. I cannot really tell the strength of the spark because of sunlight and primitive conditions at sea, but it really seems to work at idle and WOT
What went wrong?
Robert"
What went wrong?
Robert"
