Tilt amp Trim Relays
phototom1
I have a 1991 40hp Evenrude I
I have a 1991 40hp Evenrude I am having problems with the TnT relays The relay for the up position would only click when the botton was pushed I bought a new relay and same problem. the down works ok. So I swapped the up with the down and now it will go up but not down. I swapped again now it will go down and not up. Do these relays have to be replaced as a set the new relay will not work in any position. but does complete the circut so the other one will work.
Tom H
