J
Jeff Cates
Guest
"I inherited a (was runnin
"I inherited a (was running last time checked) motor. It was supposedly started about 2 years ago. I have decided to get it out and play with it. At first it did nothing (still does nothing), but I found it wasn't getting fuel. So I took the line off and replaced it. I get loads of fuel now. But I still get no start. I have pulled the carb off and cleaned it all out. But I haven't put it back on yet. My other thing to do is replace the plug and wire. It is a single cylinder. I do have good compression so I know it is fine on the ring end of things and maybe a plug and wire will fix it. But I would like help deciding what else it could be if that doesn't fix it."
