mramont895
I have the port engine showing
I have the port engine showing 190 at idle and 180 at 1500RPM's. This is the port engine the starboard engine runs around 165. The system is closed coolingThe following has been done:
- Replaced thermosat with 143
- Rebuilt raw water pump.
- Raw water exhaust elbows are new.
- Have changed gauges and same happens.
- Water temp. sending unit has been replaced
- It seems to be pumping the same amount of water as other motor. The motors have 400 hrs on them.
Once in awhile the starter will not engage and I get a clicking noise from the engine circuit breaker reset. Any thoughts?
