"I'm looking for some tech
"I'm looking for some technical advice on changing the propshaft seal on the 50's and 60's vintage 18HP/20HP Johnsons. Are there any know "tricks" for removing the old seal from the bearing carrier assembly? It seems it just has to be pried out going around and around a little at a time, but I know of at least one case where the carrier was destroyed in the process. Figured before I try mine, I'd ask the experts. If something could be expanded inside it and pounded out from the other side?? much the same way as the shiftrod bushing can be threaded and tapped out from the other side?? Any idea would be appreciated, it just seems that prying it out with a screwdriver may not be what Johnson intended...Thanks for a very informative board. John"
