Results 1 to 4 of 4
  1. #1
    searay 185's Avatar
    searay 185 Guest
    Default I removed the starter to have
    I removed the starter to have it checked out. Now I can't remember which wires go where. Does anyone know? Thanks in advance
  2. #2
    Join Date
    Apr 2004
    Location
    Posts
    237
    Default "Large terminals probably 2 wi
    "Large terminals probably 2 wires go on the large top post along with the batt cable. Yellow and red stripe on small post next to the oil pan, purple on the small post away from the pan."
  3. #3
    searay 185's Avatar
    searay 185 Guest
    Default "thanks, what wire would go to
    "thanks, what wire would go to the bottom post? a small ground wire? does the yellow and red wire go to terminal S? thank you so much for your help. next time i remove the starter i will make note where the wires go."
  4. #4
    Chris1956's Avatar
    Chris1956 Guest
    Default "Searay, On my 4.3LX, the sta
    "Searay, On my 4.3LX, the starter solenoid secondary (large copper post, with 11/16" nut) gets the battery cable, orange wire to the alternator, two or three red and red-yellow wires. Basically all the wires that are not black and have the large ring terminals. The smaller red-yellow wire runs from the slave solenoid to the starter solenoid primary winding, and is the only one on it. My boat has a mechanical fuel pump. If yours is electric, the wiring may be a bit different."
Similar Threads
  1. Replies: 6
    Last Post: 09-19-2010, 10:12 PM
  2. 81 Merc 75 wiring diagram
    By gwaircond in forum Mercury Mariner Outboard Archive
    Last Post: 07-31-2009, 08:26 PM
  3. 1972 merc 165 6cyl wiring diagram
    By mnydvr in forum Mercruiser Sterndrive Archive
    Last Post: 07-19-2009, 05:33 PM
  4. 43LX Alpha One Starter Problem
    By 94islander in forum Mercruiser Sterndrive Archive
    Last Post: 07-18-2008, 08:29 PM
  5. Help 43LX with Alpha One Gen II engine pull
    By 93regal in forum Mercruiser Sterndrive Archive
    Last Post: 07-17-2006, 03:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
