Results 1 to 2 of 2
  1. #1
    MichelleDavis's Avatar
    MichelleDavis Guest
    Default "Does anybody know what the sp
    "Does anybody know what the spark plug gap is supposed to be for a 1982 Johnson 2 stroke motor? Also the engine is overheating after about 5 minutes of running, spits water but water is really hot. Blowing white smoke also. Just had new throttle cable put on and a new overheating horn. It ran great yesterday and today it overheated and wants to die out. Any ideas? Thanks"
  2. #2
    Join Date
    Feb 2001
    Central West Florida
    Default "Plug gap is .040, Champion QL
    "Plug gap is .040, Champion QL77JC4 plugs.
    Check the compression to see if a head gasket might be failing. Drop the lower unit to inspect/replace the water pump assy."
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. '1978 Johnson 35HP Spark Plug Gap Size
    By augustus12 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-11-2010, 10:12 PM
  2. FuelOil mix and spark plug setting for 1982 40hp mariner 2 cycle
    By willy47 in forum Mercury Mariner Outboard Archive
    Last Post: 04-16-2008, 11:17 AM
  3. FuelOil mix and spark plug setting for 1982 hp Mariner 2 cyl
    By willy47 in forum Archive 2003-2009
    Last Post: 04-16-2008, 07:34 AM
  4. 1982 Johnson 35hp overheating
    By Michelle Davis in forum Johnson Evinrude Outboard Archive
    Last Post: 08-13-2006, 10:13 AM
  5. 1982 35hp Johnson Power Head Removal
    By kenny in forum Johnson Evinrude Outboard Archive
    Last Post: 10-10-2003, 12:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
