"Just joined. Brief history:
I just replaced the voltage regulator which was causing the tach to bounce around. The power-pack/sensor were also replaced due to intermittent cutting-out. The engine runs great after she get some gas. Once started, it may die at any time during idle and seems a little rough. It used to have a smooth idle, this problem seemed to start around the time everything else did...We ran some gas treatment thru the system thinking we had bad gas. I'm to the point of guessing the carbs need to be cleaned, maybe an idle circuit or something is a bit clogged? What is the best manual, tired of paying $65 an hour. Its a 2stroke.
Thanks,
Shawn"
Thanks,
Shawn"
