TAMD 41A Hunting rough idle
contender
After cruising my port engine
After cruising my port engine has a very rough idle. It has stalled at the most difficult time. Just had filters changed etc. Engine idles fine on startup. Any feedback would be appreciated.
"Most probably a fuel capacity
"Most probably a fuel capacity problem. Not enough fuel going through the injectors/fuelsystem to cool the injectors and keeping the diesel from vaporating.
May be the new filters (to high resistanc), may be fuel feed pump capacity (blocked filter in pump?), may be blocked return line(can not get rid of fuel return) Try to disconnect the return and monitor what is coming out (let it go into a separate tank). If no return or 'vapor bubbels' in return it is just to start checking from the tank to the engine."
