Results 1 to 3 of 3
  1. #1
    Default Can someone please tell me the
    Can someone please tell me the proper prop nut torque for a 1995 Evinrude 88 SPL. With the engine not running and in forward gear I can turn the prop (although with considerable resistance) by hand. I hear what sounds like the rubber bushing rubbing on the thrust washer. Is this normal even if the prop nut is torqued correctly? Thanks
  2. #2
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default nut torque would have no efect
    nut torque would have no efect on hub. it is running on a spline. sounds like a spun hub. may be visible from back of prop.
  3. #3
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "If You can turn the prop with
    "If You can turn the prop without turning the engine (when in gear) the prop needs a new bushing! It is locked to the shaft by the splines, not the nut torque."
Similar Threads
  1. Torque specs.
    By freddiedad in forum OMC Sterndrive and Inboard Forum
    Last Post: 05-04-2010, 01:09 AM
  2. B21 Torque Specs Need a double check on SELOC specs
    By followingsea in forum Volvo Penta Gas Archive
    Last Post: 08-08-2008, 03:42 PM
  3. Torque specs
    By despy in forum Mercruiser Sterndrive Archive
    Last Post: 07-23-2008, 11:40 PM
  4. Looking for Torque Specs
    By jweston71 in forum Mercruiser Sterndrive Archive
    Last Post: 04-25-2006, 07:33 AM
  5. Torque specs
    By greg in forum Outboard motors archive 2000-2004
    Last Post: 08-09-2002, 06:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
