"Hi there I bought a 1991 nitr
"Hi there I bought a 1991 nitro with a 200 HP Johnson,VJ200SLEID My first bass boat. I took it out my first time and it wouldn't idol, but it would climb out of the hole. So i made an appointment to have it serviced at a local boat shop.the compression was as fallowed #1 85psi #2 85psi #3 90psi #4 95psi #5 85psi #6 90psiThe spark was good on all the plugs they chaneg'ed the gearcase oil and lubed all the fittings test ran and adjust low speed timing, carborator and synchronization check , cooling check, gear shift operation.and checked for leaks at or around the powerhead. told me it was fine. to go fishing it would be ok. I launched the boat and now it won't climb out of the hole. I can;t get it to go over 2200 RPM's It starts to plane out and at around 2200 rpm's it starts missing and won't wind up enough to plane out. it seems to me that somthing could be set wrong when I took it to the shop the only thing that was wrong was it wouldn;t idol is it possable they set something wrong or knocked something loose. I can't get it back to the shop for three weeks. If someone has a word of advice , I would really appriceiate it. thank you very much
David Ramey"
David Ramey"
