43lx steering tight
J
jimjohnson
Guest
I have power steering but it i
I have power steering but it is very hard to steer.Do I start by replacing the pump.
"First, check the fluid level
"First, check the fluid level in the pump. Also check that the pump is spinning freely when the engine is running. Check your steering cable for any binding points."
"fluid level good,pump spinnin
"fluid level good,pump spinning freely,seems to be no binding."
"Jim, is it hard to steer in n
"Jim, is it hard to steer in neutral, or just while underway? If it is hard to steer all the time, you have a steering cable or outdrive pivot problem. If it is hard to steer while underway, you can adjust the zinc fin above the prop CCW (from top). This should help."
