Results 1 to 6 of 6
  1. #1
    Join Date
    Jul 2006
    Location
    Pasco, Washington, United Sates
    Posts
    4
    Default "i am new and am impressed wit
    "i am new and am impressed with the info i have found on this forum. i have a 35 hp gale buccaneer model #35DE10B and serial #745409. i woul like to know what year it is and what it might be worth. also it was runnung and then parked for a year. i checked the plugs and they looked good. i had run the gas out of it before parked. i took it out last weekend and it ran for about 15 min. and then died and would not restart. i know now that i had to much 2 stroke oil in the gas (about 4 pints for 5.5 gallons) oops. it also felt overly hot when it quit. i know that it is not siezed. if anyone knows what could be wrong i would appreciate any answers or guesses. thanks. incase anyone is wondering, i only had to row about 10 feet. whew."
  2. #2
    guest's Avatar
    guest Guest
    Default Well cut the oil by half at le
    Well cut the oil by half at least to start with(ad 6 gallons of gas) and if it does restart check that it is pumping water.
  3. #3
    Join Date
    Jul 2006
    Location
    Posts
    4
    Default thanks for the help. i will st
    thanks for the help. i will start by dumping the fuel tank and starting over. i have learned now that a 50/1 motor should only have 1 pt for 6 gallons. do you think having so much more oil than necessary can cause over heating? I also have another problem. the motor has a pull start and electric start. the cord for the pull start bound up. so i took th assembly apart to get at the cord and the return spring popped out and i cant get it back in. without it the assembly will not go back on correctly. sence i have electric start do i need any of the puul start assembly? it looks like the only thing that has anything to do with runability is an arm that runs in a groove on the pull start that controls 2 valves. one valve for each cylinder. with what i know of 2 strokes i don't need any of this assembly unless i want to use the pull start. am i on the right track? i can get pictures if they will help.
  4. #4
    guest's Avatar
    guest Guest
    Default The only thing the oil would d
    The only thing the oil would do is make it run like crap and smoke up a storm. The plugs will foul as well.
    That engine was made to run on 24:1 or 25:1 but that was with SAE 30 w motor oil.
    Check the color of the spark plugs after running it. They should be a nice dark tan. Try 40:1 to start with.
  5. #5
    Join Date
    Jul 2006
    Location
    Posts
    4
    Default ok. the spark plugs are defina
    ok. the spark plugs are definatly fouled then. i took them out last night and they are black. when the motor was running it did run like crap and it smoked so bad at low idle i almost couldn'tsee it. thanks for the correct ratio on the fuel/oil. i think i'm gonna take it to the water today and see if it'll run. i'll post tonight to let you know how it does.
  6. #6
    Default Re: 35 hp gale buccaneer
    I have one of these engines and about to start restoration.. This info on yours is invaluable. I'm looking for decals and plastic cowling parts. Any contacts?
Similar Threads
  1. Gale Buccaneer 5hp
    By JEMI in forum Gale Outboards
    Last Post: 12-07-2010, 12:31 AM
  2. 1970bs gale buccaneer 15 hp
    By paul_1 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-28-2008, 10:18 PM
  3. Gale buccaneer 5 hp 1962
    By caveman in forum Johnson Evinrude Outboard Archive
    Last Post: 10-25-2007, 10:32 AM
  4. Gale buccaneer 3hp prop
    By zach in forum Gale Outboards
    Last Post: 07-30-2007, 01:06 AM
  5. 1956 gale buccaneer need help
    By tolongatsea in forum Johnson Evinrude Outboard Archive
    Last Post: 04-09-2007, 09:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
