Trying to determine diameter and pitch of prop on 85HP Johnson from number stamped on prop
B
Bob Padowicz
Guest
Trying to find a replacement p
Trying to find a replacement propeller with same diameter and pitch as existing prop.
Motor is a 1973 Johnson 85HP V4. I think this prop fits on a 13 spline shaft and is used on 55HP through 120HP Johnson and Evinrude motors over an extended period of years.
The only number on the prop is W 260 and I think it was supplied by OMC.}
13 spline
13.25x17 is pretty
13 spline
13.25x17 is pretty common for your motor..
"There was one on eBay the yes
"There was one on eBay the yesterday. Steel, but it was 13-3/8x17 if that would work. Try looking under OMC Evinrude Johnson. I think that is where I was looking around. Good luck."
SS props are 13-3/8x17..
So y
So you are ok with that prop too..
