1988 V4 90 hp EVINRUDE SHUTTING DOWN
B
big tuna
Guest
"MY 90 h.p. EVINRUDE JUST SHUT
"MY 90 h.p. EVINRUDE JUST SHUTS DOWN AFTER RUNNING 4-5 MINUTES, IT RESTARTS IMMEDIATLY BUT CONTINUES TO SHUT DOWN, IT IS HARD TO GENERATE ENOUGH POWER TO GET ON PLANE AND AFTER A COUPLE OF SHUTDOWNS IT WILL NOT GET ON PLANE AT ALL AND HAS TOP SPEED OF APPROX. 6 m.p.h. IT'S PLENTY OF MOTOR FOR THE HULL SO IT'S NOT AN "UNDER POWERED " PROBLEM DOES SOMEONE HAVE AN IDEA OF WHAT MIGHT BE CAUSING THIS ? THANKS d. powell"
Sounds like you have a fuel pr
Sounds like you have a fuel problem...Start with you tank connections snd go from there..
