"If the VRO is still there, in
"If the VRO is still there, install Your tank, fill with oil, pump oil until it flows out of the hose and connect it to the VRO. You may want to check the alarm system first.
Connect the cable plug from the VRO to engine cable harness and start the engine WITHOUT oil hose conneccted. (Run 2% oil in fuel). The alarm should go off, short beep every 2 sec. If alarm works, continue as above. When connected and started, make a oil level mark outside of the oil tank, tape, marker pen etc and keep running at 1% oil mix in fuel until You are certain the engine takes oil from the tank."
