D
Dan Moriarty
Guest
"Have a 1976 aristocraft boat.
"Have a 1976 aristocraft boat. 120 hp i/o mercruiser, both wires from trim limit and trim position sensors are rotted through. I want to bypass them until i KNOW the boat works, works well. because the wires are literally in pieces, I need to know which wires can be cutm and which wires need to be put together in order to allow the trim to work, current position is all up. also I think i can replace both sensors WITHOUT pulling the outdrive, am I right can you change them( pre alpha one outdrive) I can get the the senors easily for each side, I assume all I have to do is replace and run wiring through transom. anyone done this?"
