Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2006
    Location
    odessa, fl,
    Posts
    64
    Default How do I correctly set the flo
    How do I correctly set the float level on the carbs for a 1978 140hp engine. They both overflow and I have new rebuild kits on the way. I don't believe they contain new floats so I am going to have to work with the old ones which look to be in good shape.
    With the carb upside down they appear to be about level but I don't know what the correct measurement should be.
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    543
    Default "Every rebuild kit I have purc
    "Every rebuild kit I have purchased for Johnson OB's has come with new needles and floats. I have always bought my kits from the dealer.
    The floats should be set just slightly above level on the end opposite the hinge pin. I don't know of an exact measurement, it's more of an eyeball thing.
    KJ"
  3. #3
    Join Date
    Jul 2006
    Location
    odessa, fl,
    Posts
    64
    Default Just received the kits and the
    Just received the kits and there are no floats in these kits. I haven't opened them yet but looks like there's a float gauge of some sorts in the bag. Hope it has directions!
  4. #4
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,211
    Default "(Carburetor Float Setting
    "(Carburetor Float Setting)
    (J. Reeves)
    With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked."
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. Float level 2003 25 hp
    By ram120 in forum Mercury Mariner Outboard Forum
    Last Post: 09-06-2011, 12:26 AM
  2. Float level
    By bw94 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-16-2009, 09:49 PM
  3. Float Level or Float Drop
    By maxtor in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2007, 09:04 PM
  4. Mercarb float level
    By skvitt in forum Mercruiser Sterndrive Archive
    Last Post: 08-22-2006, 11:21 AM
  5. Float level on 20 hp Merc
    By Joe Gasper in forum Mercury Mariner Outboard Archive
    Last Post: 02-29-2004, 04:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
