Results 1 to 3 of 3
  1. #1
    Jim Kleban's Avatar
    Jim Kleban Guest
    Default "I have twin Mercruiser 454
    "I have twin Mercruiser 454's on a 40' Cruisers, Inc. My port engine recently stalled after running for about 30 minutes (the last 20 minutes at about 3,700 RPM. It began running very rough and wouldn't maintain RPM's, then stalled. It restarted, but idled rough and would not maintain any RPMs, then finally stalled again. Engine temp was normal (175), and no oil loss. About 2 hours later I was able to restart it and use it to pull into my slip. We tested the engine after it was restarted, and it was smooth at several different RPM's up to 3,000 (under no stress). The same thing happened the next time we took it out, after running for 30 minutes. I suspect it might be electronic, because I have digital tach's and when I tried to restart it the RPM's on the tach would jump around from 200 to 3,000 or so. It is a '94 with 1,200 hours, electronic ignition and 4 bbl Webber carb.
    Where should I start?"
  2. #2
    Not Me's Avatar
    Not Me Guest
    Default "Jim, The pick up coil in the
    "Jim,
    The pick up coil in the distributor or a bad ground can do this. So can many other things. The grounds to the ignition are easy to check so I guess do that first. Look for loose or dirty connections. What kind of shape is the cap,rotor and plug wires in? Coil getting hot? Sounds like it is minor whatever it is."
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,389
    Default Sounds like bad gas of a flood
    Sounds like bad gas of a flooding carb.
    Jeff
Similar Threads
  1. 1978 SeaRay Mercruiser 228 stalls at high RPMs
    By ncsalpena in forum Mercruiser Sterndrive Forum
    Last Post: 03-23-2010, 06:45 AM
  2. Mercruiser surging after 20 minute warmup
    By rogerk in forum Mercruiser Sterndrive Archive
    Last Post: 06-27-2009, 07:51 PM
  3. Merc 43 Stalls At High RPM
    By mariahsx20 in forum Mercruiser Sterndrive Archive
    Last Post: 07-08-2008, 11:53 PM
  4. 2001 50L Mercruiser EFI Smoking during warmup Black and Sooty
    By robgauthier in forum Mercruiser Sterndrive Archive
    Last Post: 02-11-2008, 11:30 AM
  5. Mercruiser 140 High Idle and Stalls
    By Rod Stewart in forum Mercruiser Sterndrive Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
