"I have a very reliable 15 HP
"I have a very reliable 15 HP 77 Johnson that displays an intermittment (about 1 in 7 trips) slow speed issue. What happens is that the motor starts fine but seems to idle slow and then moving into forward or reverse the engine will run at 20% of full power at wide open throttle and then suddenly anywhere from 2-10 mins later it will "jump" into full speed. I can't figure out why it does this. I check the fuel, seems fine, I turn off, restart and that doesn't fix it. Just seems to randomly fix itself and literally jump back into full speed. It did this last year and even after a new carb, new plugs, new tank/line, new water pump and new prop (over the winter) it still does this once in a while. Very frustrating as I use my boat to get back and forth to an island cottage and have to cross a busy boating channel so i'm a sitting duck when going at 20%.. Anyone have any ideas on what I should check given we overhauled quite a few things over the winter? Note that motor starts perfectly on first pull and this often happens a few hours after I used the engine. Thanks in advance!"
