Results 1 to 6 of 6
    edmondson's Avatar
    edmondson Guest
    Default i need to rebuild lift cly b
    i need to rebuild lift cly but there are three what should i do
    Feb 2001
    Central West Florida
    14,407
    Default "Ed.... You don't say what
    "Ed.... You don't say what year or make your 100hp is. Get back to us with that info. If you're not absolutely sure of the year etc, give us the "Model Number".
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
    Default " The 2 short cylinders are th
    " The 2 short cylinders are the trim units, the long cylinder is the tilt unit. "
    ed's Avatar
    ed Guest
    Default to joereeves ihave a 100 hp
    to joereeves ihave a 100 hp mariner 08346653 i need to find out about how to rebuild the cly tokeep motor trim up and cost please thanks ed
    May 2001
    1,678
    Default "Ed, The serial number that
    "Ed,
    The serial number that you gave us does not match any of the Mariner 100 hp serial numbers. You probably have one of two tilt/trim hydraulic units. They are similar, but use different parts.
    It sounds like the check valve in the tilt cylinder is leaking. There is a kit available to rebuild the cylinder, but I would advise you to replace the assembly.
    If you could find the right serial number, I could be more specific about the part you would need. If you can tell me the shape of the pump motor I might be able to help you.
    One motor has a square base, the other has a circular base. This will help identify your model.
    [img][/img]"
  6. #6
    ed's Avatar
    ed Guest
    Default for tony it has a square base
    for tony it has a square base on left side fill hole sorry only number i found tony08346653 on small plate right side hope this helps
  1. starts but wont stay running??
    By masterboater in forum Johnson Evinrude Outboard Forum
    Last Post: 05-18-2013, 02:11 PM
  2. wont stay running 1988 5.7 305
    By jamie_bradley22 in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-28-2010, 05:11 AM
  3. Merc 1978 110 9.8 hp wont stay running
    By Cancruiser in forum Mercury Mariner Outboard Forum
    Last Post: 05-05-2010, 11:40 AM
  4. WONT STAY RUNNING
    By stevewat in forum Mercruiser Sterndrive Archive
    Last Post: 10-20-2007, 04:31 PM
  5. Wont stay running
    By mike wendel in forum Johnson Evinrude Outboard Archive
    Last Post: 05-27-2006, 06:11 PM
