Results 1 to 7 of 7
  1. #1
    chrisplumber's Avatar
    chrisplumber Guest
    Default I have a 1980 Johnson 115 yest
    I have a 1980 Johnson 115 yesterday I noticed oil dripping out of a small hole just above the lower unit water usually comes out of this hole when I have the muffs on and engine running in my driveway where is this oil coming from any help ???
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "If black, probably unburnt tw
    "If black, probably unburnt two stroke oil from the exhaust system, but check oil in gearcase anyway."
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,315
    Default "In total agreement with Mort
    "In total agreement with Mort as this is usually the case. However, should the substance actually be gearcase oil, the leak is usually due to faulty seals within the bearing/seal housing located just under the water pump plate, or at the shift rod "O" Ring.
    http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc"
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    chrisplumber Guest
    Default the oil is very black I will c
    the oil is very black I will check the lower unit oil anyway THANKS
  5. #5
    chrisplumber Guest
    Default I did not notice oil last seas
    I did not notice oil last season would changing plugs affect the oil burning off? I had gapless plugs last year but had take off power problems a johnson dealer looked up the plugs and said gapped plugs would be better??
  6. #6
    Join Date
    Feb 2001
    Location
    Posts
    14,315
    Default "Gapless (Surface Gap)
    "Gapless (Surface Gap) plugs work fine in some engines, however the gapped plugs usually result in improved all around performance.
    In your case, those gapped plugs should be Champion QL77JC4 plugs, gapped at .040 .
    http://stores.ebay.com/Evinrude-John...oard-Parts-etc"
  7. #7
    chrisplumber Guest
    Default Then I have the correct plug T
    Then I have the correct plug THANKS
Similar Threads
  1. Weep hole 1975 40 hp
    By timmyz in forum Johnson Evinrude Outboard Forum
    Last Post: 03-05-2010, 09:26 PM
  2. 88 Johnson 70hp lower unit weep hole leak
    By tnarg84 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-18-2009, 10:25 PM
  3. Alpha 1 weep hole
    By marky1212 in forum Mercruiser Sterndrive Archive
    Last Post: 05-25-2009, 09:41 PM
  4. 1982 evinrude 90hp leaking oil from tiny hole on lower unit
    By steve_bratchie in forum Johnson Evinrude Outboard Archive
    Last Post: 06-22-2008, 08:33 PM
  5. How Much should squirt from weep hole
    By BigJ1 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-11-2006, 07:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
