Mid 90bs 90 hp merc
N
Niagara Randy
Guest
"Got my fathers boat for the s
"Got my fathers boat for the summer and noticed when i take it out that it runs like a charm, I will fish for a hour or 2 with motor of go to another it doesn't run on all cylinder or something because it really goes slow, I put it neutral and raised motor a lil with trim and it reved back up ran fine. I noticed there is alot of gas smell and see some in the water when Im starting it after fishing. Could this be major problems or just a case of old gas or too much oil or carb clean?
One other problem is I used boat for a few days like this with same problems and tonight the motor wouldnt turn over after a day of fishing, all I had was lights on cause it was after dark. I put it on charger it reads 20 amps at high but on low only 2 or 3 is this normal or do I need to go grab a battery? Thanks for any help"
"Sounds like the carburetor&#3
"Sounds like the carburetor's need cleaned.(floats,needle&seats) Have the battery load tested at the local walmart or auto parts house."
