Merc 120 Carb Question
3fan
I have a 1976 merc 120 the car
I have a 1976 merc 120 the carb (2bl roch) is sucking air from where the bottom butterfly shaft goes thru and where the chock plate goes thru. My question is it worth trying to rebuild it? Or is it just time for a new one?
TIA
Gary.
I'd think it depend
Gary.
I'd think it depends on what the rebuild will cost over the cost of a new one.
If you can find a good rebuilder that will rebuild your carb and sleeve the rods when it is rebuilt at a fair price this may just be the way to go. Foresure new is best but what will it cost and you almost need it from merc so you know it has the correct calibration for the engine.
"i dunno but if you get a new
"i dunno but if you get a new one, get a holley 2 bbl marine one. They are excellent and not too $ either."
Ok thanks guys. Now can anybod
Ok thanks guys. Now can anybody suggest where and what model to buy? I know very little when it comes to buying a marine carb. I would like to get cost of new one and then see what it would cost to rebuild the one I have.
"I think this is what you want
"I think this is what you want. Surf around to find the best prices. Someone else double check me on this too.
500 CFM Two Barrel Carburetor
Part #: 0-80402-1
http://www.holley.com/0-80402-1.asp
Features
* Model 2300 w/Side Hung Float
* Dichromate Finish
* 30cc Accelerator Pump
* Electric Choke
* Power Valve Blowout Protection
* 5" Air Horn
* J-Style Vent Tubes
* Meets Coast Guard Specifications
* Single 5/8-18 Inverted Flare Fuel Inlet
* Universal Marine Calibration
* 100% Wet Flow Tested
Technical Information
Instructions for Part# 0-80402-1
Shipping Dimensions
L 12.25in x W 11in x H 7.5in
Weight 9.27lb"
