1956 15hp Evinrude
jason_m
"Does the above mentioned engi
"Does the above mentioned engine use a pressure fuel system ??? I/O, the old type of tank with two hoses going to the engine...Or will it run on the later type of tank, with the air vent in the tank cap ??"
"Notice the fuel connector at
"Notice the fuel connector at the engine, the one with two hoses attached to it? That requires the old style pressure type fuel tank.
You could use a low pressure electric fuel pump posssibly, in which case you could use the single hose tank."
"I got this engine from a neig
"I got this engine from a neighbor and it has a newer style hook up at the engine but I can,t seem to get it running..Great spark, new points and cleaned carb but not getting fuel to the plugs..."
