MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2006
    Location
    Kunkletown, PA, USA
    Posts
    18
    Default "I just bought a 1987 18ft Ebt
    "I just bought a 1987 18ft Ebtide with a 165 3.7L Mercruiser Alpha 1 drive.
    I am in the process of tuning up and going over before putting it on the water for the 1st time since I own it. This is my 1st I/O system.
    When I have started up to test run with the "Muffs" on I noticed the water was not coming out of the middle of the prop, but from where the rubber boot section is. I think those are called the bellows. I dont see a hole in them, but I assume the water is supposed to go through there to cool the lower unit, is the water supposed to exit the center of the prop?
    I did a quick visual and I only saw one rubber boot about 2 or 2 1/2" inch in diameter and it seemed to be intact, but the water was hot (from leaving the heat exchanger ) and pouring out from the area where the boot was and not the prop, so I figured I would ask before tearing anything apart.
    On my outboards the water came out a weep hole in the side of the lower unit. I dont see any holes on this drive.
    Thanks,
    Vince"
  2. #2
    Join Date
    Jun 2006
    Location
    Casselberry, FLORIDA, USA
    Posts
    73
    Default Water should come out prop hub
    Water should come out prop hub and relief ports at bottom of gimbal ring.
  3. #3
    Default You need to replace the exhaus
    You need to replace the exhaust bellows. They crack over time with heat. This can effect performance on the water. Probably inspect the rest as well.
  4. #4
    Join Date
    Jul 2006
    Location
    sebring, florida, usa
    Posts
    10
    Default I posted the same question on
    I posted the same question on another site a few days ago and a very reliable tech said with the muffs on this is normal.
  5. #5
    Chris1956's Avatar
    Chris1956 Guest
    Default "The water exiting from the mo
    "The water exiting from the motor will be close to the temperature of the motor (140 degrees on raw water cooled motor, higher on closed cooling motor). It will exit from the base of the gimbal ring (idle relief ports), and perhaps the prop hub. You motor sounds normal to me."
  6. #6
    Join Date
    May 2006
    Location
    Posts
    151
    Default 90 percent of the water will e
    90 percent of the water will exit below the gimbal (right at the transom). some will probably come out the prop too. Very normal sounding to me.
  7. #7
    Join Date
    Jul 2006
    Location
    Kunkletown, PA, USA
    Posts
    18
    Default "Thanks, guys I will check thi
    "Thanks, guys I will check this out Saturday night. Now I know where to look."
Similar Threads
  1. Water Out Of Prop When Back-Flushing OMC Cobra Drive 1987 2.3
    By DavidW2009 in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-11-2010, 09:40 PM
  2. Mercruiser alpha drive resevoir overflow during water test
    By mercuryman64 in forum Mercruiser Sterndrive Archive
    Last Post: 01-04-2009, 12:11 PM
  3. Water in Alpha 1 stern drive lube oil need help on fix
    By pktaske in forum Mercruiser Sterndrive Archive
    Last Post: 09-04-2007, 09:16 PM
  4. 280 DA Alpha 1 drive Water entering bilge from port on transom
    By Brian LaChance in forum Mercruiser Sterndrive Archive
    Last Post: 08-03-2007, 07:08 PM
  5. 72 50hp where does water exit
    By mikemartin in forum Johnson Evinrude Outboard Archive
    Last Post: 06-21-2006, 12:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
