"In another discussion I descr
"In another discussion I described a problem that sometimes my motor will run fine for a while, seems like when it warms up it sounds like it slips out of gear, the prop stops spinning and the engine revs up like it is not in gear. If I let off the throttle a little bit the prop kicks back in and everything is fine. I was told that it could be a spun prop. What does that mean exactly? What do I need to replace or fix to stop this from happening?"
