1977 Volvo penta aq130d Fuel Pump not working
"I've read thread, but why
"I've read thread, but why not wire straight to coil/ + - .Does anyone know if this takes a high or low pressure pump. Thanks"
"You could probably run a wire
"You could probably run a wire from the ignition key and ground the negative. Also, the feed pressure for the carbs should be 2-4 psi, so I don't think it would be wise to install a high-pressure pump."
"Typed out long explain and di
"Typed out long explain and didn't post. Duh.lol. Low pressure, Clymer calls for 3 PSI so El is right on the money again. I would recommend wiring to ignition switch as pumps tend to draw so amps. Mine was done by a previous owner, but they removed mechanical and replaced with a plate and the bracket for the electric pump."
