J
jwchenault
Guest
"I have an 85 XP150 that was o
"I have an 85 XP150 that was overhauled about 25 hours/2 years ago. It ran perfect last October. When I put it up for the winter I added fuel stabilizer and ran it on a hose to get it through the system. My son has used the boat twice this year had no complaints first time out. second time out he complained that it would cut out at full throttle. I finally got around to taking it out and it runs perfect up to about 35-40 MPH or 3200 RPM and about half throttle then if you hammer on it it will begin to run up normally until about 4200-4500 RPM and about 45-50 MPH then it cuts out like its running out of gas. (Normal WOT for this boat/motor gets about 57 MPH @ 5000-5200RPM depending on trim.) if you back off the throttle to about half it picks itself up and runs smooth again. I've been told by a mechanic that its probably the high speed stator gone bad, but I had a new stator put on it about 5 years ago and the hours are rediculously low. I suspect the VRO pump Diaphram as it has given trouble every 3 or 4 years since I've owned it. Usually after the engine kicks back when trying to start. I thought a diaphram kit was available for low dollars but the same mechanic who suspects the stator said that there was not a kit available he'd have to sell me a new VRO pump for $379.00! What do you guys think?"
