440 ignition timing
megabite
Appreciate if someone would re
Appreciate if someone would respond back with the ignition timing settings for both reverse and standard rotation 440's (1977). Thanks.
"Get a adjustable timing light
"Get a adjustable timing light and check the advance at cruise rpm, lots of these old dist. have bad advance units that give too much or not enough advance, I think we are supposed to have 22-25 degrees total at cruise.
Dan"
Hey Tom did You get the timing
Hey Tom did You get the timing right on your 440 s Im in the same boat with trying to get my reverse rotation motor timed 1977 440
