"Have exactly same program as
"Have exactly same program as described by Andy McCarter.
Morten - if one performs your suggested test and the engine fills up, does that mean there is an abnormal (should not exist) connection between the raw sea water flow pathway and the freshwater/coolant pathway within the heat exchanger itself? or does it mean something else?
If the engine does not fill up, then what does one conclude?
If you have such an abnormal connection the two water flows, what's the solution...new heat exchanger?
Med vanlig hälsning,
Jerry DiBona, gift med en svensk från Göteborg...och kan lite norsk (bodde i Oslo 1979-80, sabbatsår på Ullevaal Sykehus)"
