Results 1 to 4 of 4
  1. #1
    MIKEPAUL's Avatar
    MIKEPAUL Guest
    Default " I've got a '73 Chrys
    " I've got a '73 Chrysler 30hp. Here's what I've done: ran out the gas in the carb,fogged it outside(do I need to fog inside the carb and the entire engine??)Drained lower unit lube and replaced with new,wrapped motor with tarp.It will be stored outside on the boat.I know that I need to add some fuel stabilizer to the gas in the tank and bring the battery in for the year but is their anything I'm overlooking or do I have it covered? Thanks in advance for any replies. "
  2. #2
    Default Fogging is done by running th
    Fogging is done by running the engine and putting a special oil into the carb air intake.This coats the engine internals to protect from rust in long term storage.Carburetor should be empty for storage.
  3. #3
    onlineoutboards.com's Avatar
    onlineoutboards.com Guest
    Default " Hello Mike, You may want
    " Hello Mike,
    You may want to visit our site, www.onlineoutboards.com and click "tech info". There is a special section for winterizing an outboard. Might provide some useful info on winterizing. Chris - www.onlineoutboards.com "
  4. #4
    " Hello Mike,
Similar Threads
  1. Winterizing Merc MCM 898 questions
    By wish2fish in forum Mercruiser Sterndrive Forum
    Last Post: 11-10-2009, 07:54 AM
  2. Winterizing outboard
    By lmifl in forum Johnson Evinrude Outboard Archive
    Last Post: 10-25-2009, 09:01 PM
  3. Winterizing honda 90 outboard
    By sbryant9677 in forum Honda Outboard Archive
    Last Post: 11-23-2008, 07:53 PM
  4. Winterizing 85 HP Johnson Outboard
    By tricks in forum Johnson Evinrude Outboard Archive
    Last Post: 11-17-2005, 11:19 PM
  5. Winterizing Questions
    By BRRRR_In_NJ in forum Archive 2003-2009
    Last Post: 11-06-2003, 04:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
