"Eugene,
If there is enough
"Eugene,
If there is enough to grab with a vise-grip, you could try filing the bolt a bit on opposite sides, so that there are two flat surfaces for the vise-grip to bite on. Use lots of heat.
If this is not possible, the the only course is to cut the bolts even with the block, punch an indentation in the center of the bolt, and drill it out carefully. Use cobalt drill bits, and start with a 1/8 inch bit. Increase to 3/16, 1/4, etc.
After this is done, you will need a heli-coil kit of the proper size to install an insert which will accept the original fastening.
Tony"
