haffiman37
Silver Medal Contributor
"Try to hook a clear plastic h
"Try to hook a clear plastic hose close to the 'connector at the engine' and make a loope. That way You should be able to see an air buble building, if air and not just a weak lift pump. As for the tank, there are some different systems. Some has a solid tube going from top to bottom, some has a 'loose, tube that is pressed down by a niple on top. If the niple does not press properly on the tube You will have an air leak. Just take the tube out and check.
I am slightly limmited in my net access at the moment, changing my 'setup', but will hopefully be back in 'normal' in a day or two! Just opening a business centre in the condo I am living and waiting for new lines to be installed."
