"Hello,
After various recom
"Hello,
After various recommendations given to me in another thread, I bought a new stator and installed it since the old one had melted plastic/rubber substance underneath it. Same problem is occuring where the engine fires for a few split seconds and then dies. So I decied to swap out power packs with my other engine to see if the powerpack is the culprit. The engine that is running fine right now does not run with the powerpack from the inoperative engine. So I think, great it's the power pack, problem found. But just to make sure, I put the power pack from the good engine on the bad one, and the engine still does not want to run. So I swap them back to the original way they were and the good engine now runs but the bad engine is still not running. I tested the rectifier/regulator by using an ohmeter and it appears to be ok since there is high readings in one direction and low readings in the other in the various connections proposed by the manual. In short, I am running out of ideas, and would greatly appreciate any help people can provide me with.
Thanks again,
Andrew"
After various recom
"Hello,
Thanks again,
Andrew"
