1987 35 Hp Mercury
joel1
"Have 1987 35 Hp Mercury on 24
"Have 1987 35 Hp Mercury on 24' Pontoon boat, cranks fine,rev's fine but when I go past half throttle it flutters and wants to die. You can bring it back to half throttle and it runs O.K.
Any suggestions would be greatly appreciated."
"try pumping the bulb while th
"try pumping the bulb while this happens. could be lots of things tank, vent, loose fuel line, clogged main jet, stator, fuel pump. check compression and spark. first time out this year or new problem, maybe to high of pitch prop if this boat is new to you."
