K
keenan Walsh
Guest
"I have a boat that has sat fo
"I have a boat that has sat for 2+ years and the steering wheel wont turn the motor. When I loosen the nuts holding the cable in the back of the engine the cable will move and the wheel turns freely, (it does not turn the motor). When I remove the arm coming off the motor (from where a tiller handle could connect) going through the hole at the end of the steering cable the motor will turn side to side with no problem. I have put new grease in the nipples on the brackets where the cable goes into the motor and still nothing."
