"Greetings,
This is my firs
"Greetings,
This is my first post. I have been searching and searching for a GOOD volvo sterndrive forum.. I think I have finally found it!
On to my question, first my boat's engine starts to run very hot and finally overheated the last couple of outings when the boat is on plane. The first time, I inspected the raw water pump's impeller to find it missing a blade with the blade lodged in the thermostat housing. Well, I thought problem fixed.... No, the next time out with the boat it did the exact same thing.... got hotter and hotter the longer the boat stayed on plane (which depended on the skill of the wakeboarder..haha)
Anyway, to ensure that I have absolutely no air leaks between the drive water inlet and the raw water pump, I am planning on replacing all the o-rings, seals, gaskets, etc. in the water tube assembly located in the intermediate housing.
My clymer shop manual says to remove the drive from the boat to remove the intermediate housing. Are there any short cuts for replacing all these seals, etc for the water tube assembly?
Or, after reading some of the posts on this forum, should I start with replacing the clam shell hose fitting on top of the drive (I do remember the hose connecting on this starting to disintegrate the last time I look at it), S shaped hose, and the suction line to the raw water pump? Also, I have a rebuild kit on the way for my raw water pump.
What if I just re-sealed the lower drive section? Shouldn't this theoretically eliminate any air leaks?
Thanks much,
Chris"
This is my firs
"Greetings,
Thanks much,
Chris"
