1988 Johnson 90hp
alarider
My 99 Johnson 90hp was running
My 99 Johnson 90hp was running fine when it suddenly lost power. It would lose power then kick in and run fine then lose power again. Cycle last about 8 seconds on then off. If I push in primer it runs fine. Any ideas?
Sounds like its carb cleaning
Sounds like its carb cleaning time..! The fact that it will run with the primer tells that the carbs are the problem...
"Good idea! Do you think a can
"Good idea! Do you think a can of carb cleaner spray throught the screw fitting on the primer is good enough, or should I take her apart."
"Rebuild the carbs and pay att
"Rebuild the carbs and pay attention to getting the jets clean....no need to remove them, just make sure that they are open.."
""No need to remove them&#
""No need to remove them" surely refers to the jets, not the carbs. I wouldn't want to service them in place!"
